For the most part, applying the load as a pressure or as distributed loads should produce minor variations in the results, especially if looking at regions remote to the point of load application.
I believe that a pressure distribution adjusts the loads at each node to provide a balanced loading. What I mean is that if you have an axially loaded bar, and you apply a pressure to the end face, the bar will expand uniformly such that the end face remains plane. Now if you were to apply the pressure as discrete forces, all of equal value, then you would see more deflection around the free edges and less in the middle as the face dishes. If the other end of the bar is a sufficient distance from the applied face, then both methods should produce the same stresses at that end.
jetmaker
