Force Transfer - Steel Column to Concrete Pier 1
PEFLWI
120
Does anyone know of a design resource for a steel column embedded in a concrete drilled pier? See the attached sketch. I need to transfer the bending moment and shear from the column to the pier. As far as I know there were no shear studs to transfer forces.
 https://files.engineering.com/getfile.aspx?folder=064e8f00-2aff-49f4-8644-394516e8d586&file=Steel_Column_Embedded_in_Concrete_Drilled_Piers.pdf
Nowadays, I think that I'd be looking to the research and design provisions surrounding the use of steel coupling beams in concrete shear walls: Link. The big question is what's the effective flexural embedment depth and the coupling beam stuff provides an answer to that I think.
