Forcemain Cost estimates
gomirage
53
I have been given the task of comparing two altertnates.
Either build a WWTP on site for treating industrial/domestic waste or construct a sewer force main to take the waste 10 miles and connect to an exist sewer system. I am starting with the second alternate, meaning estimating the cost of a 10 miles forcemain. Can anyone give me some help regarding:
-- Some documentation on parameters to consider for the design of a FM.
-- Types and cost of pipes, lift stations, etc.
-- Some hydraulic models
-- etc.
any help will be greatly appreciate.
Thank you.
--Doc. on parameters to consider:
for the design of a FM: pages 28-35,
for the design of a WWTP: pp37-111,
but your state/province will have their own...use that one. The guidelines will be similar enough for prelim. cost estimating.
--costs:
WWTP will require an Operator forever, PS will require substantially less O&M.
Other costs vary too much w/out more info, but I would guess a small package WWTP might be more attractive than 10 miles (!) of FM.
--hydraulic model:
Use Hazen-Williams. Use smallest D at known L and Q to get reasonable hf. Apply to Bernoulli's, with known z and v, to get dP. That will size pump.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
Uni-Bell PVC Pipe Association has a brief manual called Forcemain Design using PVC pipe, and they also sell a Handbook of PVC PIpe, very informative. Also could contact IPEX in Canada or US who provide tech, info. on PVC and other plastics (
Plasguy
