newyeareve
- Oct 19, 2015
- 2
Hi guys,
I'm working on a tooling control project for a train maintenance depot. I'm creating this post in hope to gather your thoughts, experience and advice on the followings:
Do you think FOD control is important for rail?
Have you come across any incident/accident caused by FOD?
Recently I've been reading FOD control in the aviation industry, which is an important aspect in the industry due to accidents happened in the past. There are extremely strict control procedures for toolings enforced especially in the maintenance facilities for planes and jets.
By comparison, the tooling control in maintenance depots in the rail industry is a lot more relaxed at the moment.
I've included below some background information for FOD:
Foreign Object Damage is damage caused by Foreign Object Debris that compromises the quality, functionality or economic value of a manufactured item. For instance, a piece of FOD at the wrong place at the wrong time can:
•Shred fan blades when sucked into a turbojet
•Blow out tires at high speeds
•Damage delicate components when trapped inside of an equipment housing
•Freeze control mechanisms when lodged next to levers and handles
Foreign Object Debris is any object, particle, substance, debris or agent that is not where it is supposed to be.
Examples of foreign object debris:
•Tools, parts and loose hardware
•Building materials
•Paper, paper clips, pens, coins and badges
•Fragments of broken pavement
•Trash, food wrappers and beverage containers
•Rocks, sand and loose vegetation
•Baggage tags and pieces of luggage
•Hats, rags and gloves
•Building materials
