jmec87
- Nov 5, 2013
- 225
I know that forging reduction ratio is defined as the ratio of the original to the final cross-sectional area. However, I've recently encountered the suggestion that if an ingot is upset to increase the cross-sectional area before being forged to reduce the cross-sectional area, the reduction ratio is the ratio of the upset cross-sectional area to the final cross-sectional area. Is this reasonable? Can anyone recommend any references (such as standards or ASM handbooks) that would clearly allow or disallow determining the reduction ratio this way?
Example:
Ingot size: 20" diameter
Ingot upset to size: 24" diameter (for the whole length of the forging)
Final Forging size: 10" diameter
In this case, would the reduction ratio be (20^2)/(10^2) or (24^2)/(10^2)?
Example:
