thread507-122331
I would be grateful if Engineer jike could kindly enlighten me on how to design for the bottom distribution steel of a concrete slab (that is subjected to concentrated loads due to forklift truck) which has been stated to be significantly larger than the normal temperature steel in Engineer jike's comments at the above forum on 26 Apr 2005 17:06 as shown in the attached screenshot.
FYI, I always thought that for a one-way structural slab, its bottom distribution steel shall be the normal temperature steel as specified in the reinforced concrete design codes.
Thank you.
On S. H.
Thank you.
On S. H.
