Oct 17, 2024 #1 CAD2015 Computer Jan 21, 2006 1,925 0 0 US Hi, Some CAD systems have the Format Painter capability: Does NX have this enhancement, too? I'd like, for instance, to make note 1 at the same size as the note 3: It may save time......... Thank you.............. CAD 2015
Oct 17, 2024 1 #2 cowski Mechanical Apr 23, 2000 8,140 0 36 US Right click the label that you want to change and go to 'settings'. In the settings dialog there is a section called "Inherit"; change the settings source to "selected object", then select the object that you want to inherit from. www.nxjournaling.com Upvote 0 Downvote
Oct 17, 2024 Thread starter #3 CAD2015 Computer Jan 21, 2006 1,925 0 0 US Thank you for advice, it works just fine! CAD 2015 Upvote 0 Downvote
