Format Painter in NX drawings................... 1
CAD2015
Computer
Jan 21, 2006
2,032
Some CAD systems have the Format Painter capability:
Does NX have this enhancement, too?
I'd like, for instance, to make note 1 at the same size as the note 3:
It may save time.........
Thank you..............
CAD 2015
Right click the label that you want to change and go to 'settings'. In the settings dialog there is a section called "Inherit"; change the settings source to "selected object", then select the object that you want to inherit from.
www.nxjournaling.com
Thank you for advice, it works just fine!
CAD 2015
