Forming and possible Delamination on the INSIDE??
U2tree
Industrial
Mar 4, 2011
13
this is 11 ga pickled and oiled sheet
anyone ever see this happen or know what might cause it??
yes I use to Inspect sheets and Plates for delamination from the mill. it was common, pull the raw stock and have it visual inspected.
A quick thickness test using a ultrasonic thickness mic using a dual element transducer can detect laminations in many thickness ranges, but probably not the best choice for materials least than 1/8-inch thick.
Best regards - Al
