fortran compiler for parallel programming.
ProfLIN
1
Any available free fortran compiler for parallel programming
If you are just using openmp, try gfortran.
gfortran will also work with cuda - that is, if you have an nvidia graphics card. It uses the graphics card as a parallel processor.
If you do not have an nvidia card, try gfortran with opencl.
Gfortran is free and can be used together with MPI or OpenMP. For the Windows application, the Intel Fortran compiler is easier to use but not free.
Note that MP is the parallel interface, MPI is the message passing interface, which is sometimes used for parallel processing.
