Eng_Struct
- Sep 23, 2022
- 69
Hi Group,
I am looking for foundation design guidance for a 40m tall and 2.5m in diameter stack for an industrial building. The native soil is 3m below the finished grade and will mos likely require a deep foundation solution.
What are the design considerations i.e., seismic and wind lateral load, overturning, and sliding? I am thinking a 3.5 (W) x 3.5 (L) x 1.2 (D) concrete pile cap on concrete caissons or H-Piles around the perimeters and in the middle. The push and pull action on the piles will help resist the overturning. I will have to engage geotech to work out the resistance of pile skin friction for uplift/tension. I am thinking I will also require P-Y curves for soil structure interaction for bending moment and shear force values on caissons/H-piles for their design.
1. Any other watch-its or considerations I need to pay attention to?
2. Any design references or guidelines for Canadian industry for the foundation design of stacks will be helpful?
3. My challenge will be designing the pile cap (probably using strut & tie method) to transfer the loads to the caissons/h-piles. Are there any tools out there that can assist with pile-cap design?
Thank you all!
Thank you all!
