untitled1
Specifier/Regulator
- May 13, 2008
- 2
I am looking for some advise for a suitable foundation to use for a small cottage where there is 5 feet of clay over top of very flat limestone bedrock. It's in Canada where the frost (not permafrost) goes down to the bedrock. I'm considering some type of pile system and am concerned about frost heaving.
If I were to drive small diameter steel posts would I need to anchor them to the bedrock, or would the small amount of surface area make the lifting negligible (or is there a way to "grease" the posts to prevent this)? If needed, is there a way to get an anchor into the the bedrock without digging a man-sized trench, I'd like to disrupt the site as little as possible?
Also of concern is the lateral stability of such short posts - are the posts liable to tip over?
Alternatively, if I were to use concrete, would belling out the bottom of the pile stop any lifting? I found a link on this site that suggested such a system using plastic cone-shaped formwork -
Any suggestions will be appreciated.
