Foundation Wall Waterproofing
dik
CA
What is the current best practice for this... I don't usually do foundations, but the client has a large pit (not deep) but there is a significant high water table (about 3' below grade). I've designed the pit for buoyancy and he doesn't want to provide perimeter drainage and/or sump.
I used to use a product called 'Blue Stuff' which was great, and I don't know if it's currently available.
What coatings do most people use these days?
Just came across Henry-Bakor Blue Seal waterproofing membrane... looks a lot like 'Blue Stuf'. I think Bakor made 'Blue Stuf'... anyone use it?
Just found it... Blue Stuff by Pennkote... Is there a better product?
Typically can't use perimeter drainage and sumps for tank foundations below the water table, the pumps can't keep up with drawing down a water table. Full waterproof under the floor and up the walls. I have used Henry products, including Blueskin sheet membranes often for the walls. There is a different loose laid membrane for the underslab portion that is typically installed on a mudslab before the base slab is poured. Can't recall the specific product name. The underslab membrane is then lapped with the wall membrane for a water tight system.
HLM5000 by BASF was always our typical below grade waterproofing specification. It's a fabric reinforced roll on product. The contractors don't really like it, mainly because they can't just spray/roll it and be done, but the fabric reinforcing makes a huge difference in our experience.
Thanks very much, gentlemen (my binary term for PC).
Thanks Canuck... it was an initial concern, but water flow is low in the soil, but an embedded perf pipe fills up. I've gone with a 2' thick concrete pad... and waterproofing.
I use bentonite rod all the time for waterstops... have for decades... I prefer it to PVC stuff...
