zrck99
- Dec 19, 2014
- 82
I am designing a frame with tension only diagonal bracing that stops midway up the structure. I am landing on an 8" slab at the base and would like to stick with pinned connections at the base. I'm kind of having trouble wrapping my head around how the upper diagonal braces create rigidity such that there is only shear and axial force in the column at the baseplate. Does anyone have any ideas for a way of explaining this? I've seen approximate methods for dealing portal frames having moment connections at the beam to column connection in the upper corners and am guessing that this is similar but am still having trouble picturing the actual statics of what is happening here. I would appreciate any attempts from people trying to explain this. I think I may be in need of an "Explain it like I'm 5" level of explanation here. I've attached a sketch of the general situation.
