cslater
- Jun 27, 2007
- 46
I'm working on a redesign/retrofit of an existing metal shop building. The structure is made up of 4 rigid frames, 40 feet wide and spaced 25 feet apart.
The roof covering is supported by longitudinal purlins at 48" o.c., covered by metal roof sheeting. The existing design uses 3/8" diameter cable cross bracing in the roof, but only in the sections that directly line up with shear bracing in the walls.
I have the as-built calculations, but its not clear how the shear is being transferred to the shear resisting wall panels for the portion of the roof that doesn't have cross-bracing.
It doesn't seem like sheet metal roofing would have the shear capacity needed of the diaphragm, but I can't see anything else providing it. Can anyone shed any light on the design process behind this type of structure?
Sorry for the long-winded, confusing description, and thanks in advance for any help on this.
