I am running a free Convection heat transfer experiment in which I am trying to determine the heat transfer coefficient of a long horizontal cylinder. The experiment requires that I find this coefficient by means of measuring the surface temperature and using that along with the ambient temperature and dimensions of the cylinder to determine the heat transfer coefficient. I am currently using a 120W Cartridge heater with 5/8" diameter and 6" long and varying the wattage I put into the heater.
When I calculate the heat transfer coefficient from Newtons law of cooling Q=A*h*(Ts-To) I get one value and when I use the correlations for heat transfer of a long horizontal cylinder I get a significantly lower number. I have tried this at different wattages and have come up with the same results of between 40%-55% error between the two heat transfer coefficients. Can anyone help me with what I might be doing wrong or why this error is occurring?
