You need to calculate the vertical sides seperate from the top & bottom surfaces. THen add up the conductivities using formulas for parallel resistances. "Advanced Heat Transfer" by Rosenhow & Choi has simplified formulas for upward facing, downward facing and verticla surfaces in contact with air.
