Just doing a sanity check with this one.
I have a client who is looking to add an elevator outside of an existing wood framed building. The elevator shaft is to be constructed using 8” cmu on all 4 sides with dimensions of 8’-2” x 9’-7” (I know this is not coursing, but it’s what is required by the elevator manufacturer) and be approximately 25’-0” tall. Code is IBC 2015 with Vult=131 mph
Because of the nature of the existing structure, this new elevator shaft will need to be free-standing. I have checked each wall to act independently from the other as shear walls, that is, I am not relying on the shaft to act as a continuous cantilever tube but rather 4 shear wall elements. Everything seems to be working easily. I know the walls will want to span horizontally rather than vertically, so I will more than likely add some additional horizontal bond beams to the structure.
Is there anything I am missing here? Can’t say I have ever done a free-standing masonry elevator shaft before; we usually clip them off to the support structure for stability purposes.
