I have an application that uses a 100% outside air intake with a HW coil in the duct. The application calls for freeze protection with a pump. Problem is, there is no schematic on this. I've searched high and low for something with no results. Can someone provide me either a schematic or explanation of what is involved in such a case? Assuming the main loop pump cannot circulate the necessary flows needed for freeze protection.
Namely:
Should the pump run at all times?
I appreciate any advice offered and hopefully with gained experience I can contribute more than just questions to the forum.
Namely:
If not, what are the controls(automated valves, etc.) needed?
I'm assuming this loop will need check valves?I appreciate any advice offered and hopefully with gained experience I can contribute more than just questions to the forum.
