Freeze Protection Standards
YungPlantEng
Chemical
Jan 19, 2022
91
Was wondering if any standards exist on freeze protection exists for tank farm pumps that are not always recirculating (or might fail to start due to misc. issues) as well as condensate piping due to boiler transient outages. Would I need to install by-drains at every possible dead leg or would the fluid expand in such a way that I could more strategically select where to put these?
Thanks!
Not sure there is any sort of standard here but can you elaborate?
When process streams go stagnant and stream temps drop, heat tracing kicks in where freeze protection is required to prevent plugging in piping. Electric heat tracing is more reliable with no hot spots compared to steam tracing. Steam traps are usually provided at low points in steam piping.
I don't know of any industry standards but large Oil and Gas, refining and chemical plant companies have their own specifications for Winterization and Heat Tracing. I have some but should not share on internet. However if you do a search for winterization or winterizing and heat tracing you can find some company specs on the internet. Here is one I just found doing the search below. Also you can find a lot of articles and guidance about winterization on the internet by doing the same search.
