Freezing of pilot sensing lines
Alabaman
Chemical
Jul 19, 2006
Hello I have a quick question. What effect does freezing of pilot sensing lines have on its operation? Pre mature lifting? or potential for overpressure? Any insight will be appreciated. Thanks
Either one. When water freezes it increases in volume by approximately 4%. If there is a couple of feet of tubing between the freeze point an the pilot, it would be just like shutting a valve and trapped pressure will only increase slightly. If the freeze is very close to the pilot, it can simulate a very high pressure (especially if there is liquid water between the freeze and the pilot.
Heat tracing and insulating pilot lines is a very good practice.
David
Pilots freezing, plugging, or contamination in general is potentially dangerous. if freezing is a concern, heat trace and insulate is a good idea as zdas04 mentioned.
I am presuming the source of freezing is due to ambient conditions. If the freezing is due to process conditions, heat trace/insulate may not work and you will need to find alternatives.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks all. I understand theoriticaly why a pilot valve will open prematurely before reaching its set point if the sensing line freezes.
However, I still dont understand why it will NOT open when it reaches set point due to sensing line freezing up. The operators i spoke to said they haven't seen this before. Can some one explain if this is indeed a likelihoo?
Thanks.
Did you read my post? The freeze can act like a shut block valve which makes it really hard for the control valve to close.
David
