the motor has combination of ball bearing and cylindrical roller bearing on the drive end. only cylindrical roller bearing on the non drive end side. The motor running in decouple condition the axial vibration is higher side comparing with horizontal and vertical. The thrust ball bearing failure frequency is every year
Driven machine has sleeve bearing with thrust collar axial float max 0.5mm
flexible coupling with 6.5mm gap between tow hubs
Is this symptom indicating the motor magnetic center not set properly
Motor : 2200HP
RPM :590rpm
thanks....
some of the pictures and vibration details are attached pl refer. this motor bearing dismantling is under progress
(attachment 14 Jul 16 10:59)
thanks to all your very useful posts and brain storming
most of your assumptions are matching with mine.
last year I have raised a modification proposal that too enclosed with this post please find the attachment.
(attachment 17 Jul 16 12:22)
As Mr Muthu comments I agree that with cylindrical and ball bearing combinations are working well without any problem. these all motors are driving which has anti friction bearings
the problem which has friction bearing with larger radial clearances, also when the motor is in operation motor and the blower shaft runout was measured blower side 0.15 to 0.20mm motor side 0.15mm the peak raise looks both shaft moving with the same timing
a sectional drawing also attached it may help to get more details
grease: SHC 100 mobile
intervals : 1000 hrs/ 40g
when the motor shaft rotates manually no movement found on the ball bearing. the movement force coming from the driven machine when the motor operates with rated load and RPM
The thrust bearing wear pattern studied most of the housing and thrust bearing end cover step bearing seating area found worn out around the bearing outer ring.
After installation the thrust bearing alignment was inspected there is no scew found.
one more experiment done while operation in rated load and RPM motor thrust bearing end cover loosen found that motor vibration came down 3.6mm/sec to 1.9mm/sec same time two dial indicators on drive and driven shafts measured 0.15mm in both shaft no difference in runout readings after loosening the thrust bearing end cover its conforming that thrust bearing is oscillating
greasing we under discussing with the mobile to select suitable one
now I collecting all the damage bearings once dismantle bearings and ensure the wear pattern indications
modification still not started looking for more information
