krisys
- May 12, 2007
- 458
One of the remote oil fields we have many Chemical Injection (CI) skids installed at various locations. These CI skids are installed recently (between 1 to 3 years old). Each CI Skid is having single pump and intended to be operated continuously.
The pumps are driven by 24V DC Permanent magnet Ex ”d” motors (motor rating is 0.18 kW). We are experiencing pre-mature failures of these motors, primarily due to the requirement of frequent maintenance (requires quarterly inspection/ maintenance/ replacement of the carbon brushes).
One of the consultants have suggested to replace the existing DC motors with inverted type motors. The inverted motor is essentially an AC induction motor with embedded inverter in the volume of terminal box. Hence there is a possibility of in-situ replacement.
Has anyone in this forum having any experience with this type of motor? How reliable these motors are for the prolonged trouble free operation.
Sharing of any such experiences is well appreciated.
