Hello everyone,
I was wondering if you could point me in the right direction.
I have an object on 4 x 100mm hard rubber castor wheels on a flat concrete. The object weighs roughly 1000kg.
What force would be required to pull the object?
I have been looking at this website as an example https://www.omnicalculator.com/physics/friction
Looking more specifically at calculator 2 and 3 on the website, I get that one uses a dimensioned friction coefficient and the second uses dimensionless, but why do the values vary so much? Even when comparing that the rolling resistance value is 0.35 https://www.bulldogcastors.co.uk/blog/castor-wheels-roll-resistance/ and for rubber even being a value of 1 (Example of friction values https://web.mae.ufl.edu/designlab/Class Projects/Background Information/Friction coefficients.htm)
Surely it would be easier to pull an object with 4 rubber wheels vs the surface being just rubber on concrete?
Thankyou
Thankyou
