StephenMontgomerSmith
Student
I have a gear system, where one shaft S1 drives a second shaft S2. The gear system works equally well whichever direction I turn S1.
Now I want to turn S2 to drive S1. I find that the friction becomes quite a bit greater.
I did quite a bit of web searching, and I also asked Mechanical Engineering Professors. I didn't find anything, except some very technical papers on friction in gear systems. I have also done some thinking about it. The only difference I can see is the the gears slide over the same surfaces, but in the opposite direction.
