geesamand
- Jun 2, 2006
- 688
I have a project where a customer is interested in using aluminum to build a differential housing instead of cast iron. All my past experience is in cast iron - as far as bearing fits, working stresses, machining, casting, etc.
The goal is to design a stronger/stiffer housing than the OEM cast iron unit. The aluminum option is intended to save weight.
What material should I consider for my aluminum casting? What is the most reasonable casting process for producing under 200 units? I intend to contact the bearing manufacturer for housing fit recommendations.
Any tips appreciated.
David
David
