From User Proprieties to Title blocks macro catia
Olivia86
Automotive
Sep 23, 2016
29
What i'm tryng to achieve is a macro that read the String.1 USER PROPRIETIES of the current part used in the sheet, then finds the related title block "TitleBlock_Text_PlyName" for example, and then copy the value of String.1 in the relative text box.
If you can provide any peace of codes or other helpful stuff i will try to make and share the macro with you.
thanks in advice
I tought that this peace of code found in the catia examples would eventualy help me, but this code seems to not work at all, it's not even giving error.
If i get this right this is taking the part number name and it's filling TitleBlock_Text_Number_1 with the PartNumber, this would be the solution to for my macro, but it's not working.
Code:
Sub CATLinks()
  'How to fill in texts with data of the part/product linked with current sheet
  On Error Resume Next
    Dim ProductDrawn As ProductDocument
    Set ProductDrawn = DrwSheet.Views.Item("Front view").GenerativeBehavior.Document
  If Err.Number = 0 Then
    DrwTexts.GetItem("TitleBlock_Text_Number_1").Text = ProductDrawn.PartNumber
    'DrwTexts.GetItem("TitleBlock_Text_Title").Text  = ProductDrawn.Definition
    Dim ProductAnalysis As Analyze
    Set ProductAnalysis = ProductDrawn.Analyze
    DrwTexts.GetItem("TitleBlock_Text_Weight_1").Text = FormatNumber(ProductAnalysis.Mass,2)
  End If
End Sub
I had found a problem, i have to change a text that is inside a ditto. But the ditto could not be exploded, how could i find the text in that case?
Let's change the approach... if i have this "path" that is generated by a detail Modifiable in instance that was created with instantiate 2d component. How can i edit the text inside? Since the search query is not finding the instantiated items i cannot use the
selection3.Item(1).Value.Text = "Text2"
Any suggestion?
I would expect something like
Text.2/2D Component[2]/Background View = "some other text"
Search the V5Automation.chm Help file in your CATIA Installation path for DrawingComponent. It has a method called GetModifiableObject() the will retrieve the Modifiable objects in the 2dComponent.
