when do you draw the line when deciding frost footing with cmu wall for slab support, vs. monolithic slab.
reason i ask is that I will have to bring in 4-5' of fill to get slab up to grade. then a retaining wall, etc(not in that order specifially). OR should I do the frost footing and cmu instead?
is there a code to follow in regards to this?
best,
dc
best,
dc
