MBGraham
Chemical
- Mar 9, 2021
- 41
This concerns a proposed service water line from municipal supply to a residence location that is built on a slab-on-grade. This is in Ontario, Canada with lowest winter temperatures -18F or -27C. I have searched codes but not found answer to my question below:
According to code, water line must be 5ft below grade. Question is - How far under the slab from perimeter wall must line penetrate horizontally before the vertical entry through the slab floor.
Depending on the distance, this could mean the line would be in impractical spot within room. If so, are there any regulations or codes that would allow the vertical line to be closer to the exterior walls?
If this question would be better in a different sub-forum, pleae advise. Thanks
