I need to create contact between frp (shell element) and two solid surface (sandwich).
so i created an area between the solid surface (exactly at the mid loc between solid surfaces).....
number 1 and 2 represents contact at lower and upper of frp plates.
the script for both contacts are;
contact no 1;
contact no 2;
but i keep receiving warning message;
*** WARNING *** CP = 1013.047 TIME= 16:12:00
The geometric gap/penetration may be too large. Increase pinball
radius if it is a true geometric gap/penetration. Decrease pinball if
it is a false one.
the gap between 2 solid surfaces is 1.2mm (exactly the size of frp final thickness
how to solve this problem?
thanks
contact no 1;
Code:
!CONTACT SURFACE BETWEEN AREA 14 AND 73
R,4 !DEFINES THE ELEMENT REAL CONSTANTS NO 4
REAL,4 !SET THE ELEMENT REAL CONSTANT 4
!GENERATE TARGET SURFACE
ET,5,170 !TARGE170 ELEMENT NO 5
ASEL,S,AREA,,14 !RUBBER LAYER SURFACE
CM,TARGET,AREA
NSLA,S,1
ESLN,S,0
TYPE,5
ESURF
!GENERATE CONTACT SURFACE
ALLSEL
ET,6,174 !CONTA174 ELEMENT NO 6
KEYOPT,6,2,2 !CONTACT ALGORITHM-MPC APPROACH
KEYOPT,6,4,2 !LOCATION OF DETECTION POINT -ON NODAL POINT NORMAL FROM CONTACT SURFACE-RIGID SURFACE CONSTRAINT
KEYOPT,6,9,1 !Exclude both initial geometrical penetration or gap and offset
KEYOPT,6,11,1 !THICKNESS EFFECT : INCLUDED
KEYOPT,6,12,5 !BEHAVIOUR CONTACT SURFACE - BONDED ALWAYS
ASEL,S,AREA,,73 !FRP SURFACE
CM,CONTACT,AREA
NSLA,S,1 !SELECTS THE NODES ATTACHED TO THE AREA
ESLN,S,0 !SELECTS THOSE ELEMENTS ATTACHED TO THE SELECTED NODES
TYPE,6
ESURF
ALLSEL
contact no 2;
Code:
!CONTACT SURFACE BETWEEN AREA 19 AND 73
R,5 !DEFINES THE ELEMENT REAL CONSTANTS NO 5
REAL,5 !SET THE ELEMENT REAL CONSTANT 5
ET,7,170 !TARGE170 ELEMENT NO 7
ASEL,S,AREA,,19 !RUBBER LAYER SURFACE
CM,TARGET,AREA
NSLA,S,1
ESLN,S,0
TYPE,7
ESURF
ALLSEL
ET,8,174 !CONTA174 ELEMENT NO 8
KEYOPT,8,2,2 !CONTACT ALGORITHM-MPC APPROACH
KEYOPT,8,4,2 !LOCATION OF DETECTION POINT -ON NODAL POINT NORMAL FROM CONTACT SURFACE-RIGID SURFACE CONSTRAINT
KEYOPT,8,9,1 !Exclude both initial geometrical penetration or gap and offset
KEYOPT,8,11,1 !THICKNESS EFFECT : INCLUDED
KEYOPT,8,12,5 !BEHAVIOUR CONTACT SURFACE - BONDED ALWAYS
CM,CONTACT,AREA
TYPE,8
ESURF
ALLSEL
it is a false one.
thanks
