frustrated with SW2003 1
dogarila
CA
I recently upgraded to SW2003 SP3.0 and I deeply regret it.
I wonder what did I gain? The major difference between SW2001Plus SP6.0 and SW2003 SP3.0 is that the last one is much much slower. Instead of increasing my productivity (as expected from a newer software) it reduced it a lot. I spend now most of my time waiting for SW to switch from a part to the assembly or saving/opening files.
My system is an IBM IntelliStation with two processors P3 at 731 MHz, 1 GB RAM, graphic card is an ELSA Gloria II with 64MB RAM.
Another thing I noticed:
In SW2002Plus SP0, every time you opened and closed a file SW was asking you if you want to save it(even there was absolutely no change to the file). At a later SP they fixed that. In SP6.0 if the file was not changed SW would close it down without asking you whether you wanted to save it or not.
Now they are back. Looks like the flag they are supposed to keep to control whether a file was changed if doesn't work properly. Correct me if I am wrong but this is waht happening on my system. I open a part, close it, answer yes to the question whether I want to save it, open the same part, close it, the question pops up again. Annoying.
Andrew
