Excellent forum hopefully I can find the person with some insight to my questions. I did not see any information relating to my post in the past threads.
In common rail (gasoline) fuel systems there are usually pulsation dampers designed in the system to decrease pulsations inside the fuel rail with may cause fuel suppl;y problems (lean conditions) under heavy cycles.
My question: (two parts)
What if any would be the effects of removing this damper from the system all together? If I would run into ill effects how could I test for it? Any thoughts?
What if the fuel system has been highly moddified?
~fuel injectors changed from 230cc to 550cc
~increased fuel feed lines and return lines
~much larger capacity fuel pump
I'm just looking for some opinions from some experienced fuel systems engineers/designers/etc. Most people I ask say to simply eliminate the damper, but I don't think that is a good enough answer if it's not backed up by some fact.
Thanks for your time,
SLPR
SLPR
