Zogzog
- Mar 7, 2006
- 1,579
Possible this report was not true
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
explosion occurred near the suppression pool in the reactor's containment vessel.
The seal around a reactor at a quake-damaged Japanese nuclear power plant does not appear to have been holed, the plant operator says, following an explosion at the plant.
Chief Cabinet Secretary Yukio Edano told reporters earlier on Tuesday that the suppression pool of the No.2 reactor at the Fukushima No.1 plant appeared to have been damaged.
The pool forms the base of the container vessel which seals the fuel rods.
Plant operator Tokyo Electric Power Co (TEPCO) "said it believes the container vessel has not sustained damage such as a hole, judging from the fact that the radiation level has not jumped," a spokesman for the country's nuclear safety said.
A third reactor exploded late Monday at the Japanese nuclear plant crippled by Friday's earthquake, releasing a dangerous amount of radiation, officials said.
A fourth reactor was on fire and there were fears that the steel containment vessel protecting the plant's nuclear core had been breached - the worst-case scenario in such situations.
"There is a very high risk of further radioactive leaks," Prime Minster Naoto Kan said in an address to the nation."I ask you to stay calm."
More than 180,000 people living in a 12-mile radius of the Fukushima Daiichi plant 150 miles north of Tokyo had already been evacuated over the weekend.
Kan asked that people living between a 12- and 18-mile radius hunker down inside.
"Remain indoors, at home or in your offices," he said. "Avoid going outside."
Officials evacuated staff plant after reactor No. 2 exploded - the third blast there since Saturday.
A heroic team of 50 workers stayed behind to continue trying to cool the reactors with seawater and avert large-scale meltdown.
"They are putting themselves in a very dangerous situation," Kan said.
Tokyo Electric said a reading of 8,217 microsieverts per hour of radiation was taken at the plant's gates after the explosion - a fourfold increase from 40 minutes earlier
