Hi All,
I would like to know if there is some difference in radial loading capability at different angular positions for a full cylindrical air journal bearing. This type of bearing is used to support shafts in air-bearing spindles. I am trying to understand in context of this figure (see link) which shows the difference in the air film thickness (lubricant in this case) at different angular locations. What would be the relationship between film thickness at a particular angular location and its radial load capacity?
Thank you,
Thank you,
