hello folks,
I am getting this info second hand so bear with me...
An electrician asked me whether I knew what the term "full load amp runout" meant? The electrician had sized a cable for a motor load (60m away) at 300mcm from the motor spec sheet. The engineer on the job said he wanted 400mcm to cover the FLA runout.
The only thing I could think of was that the engineer might be using this term to refer to the voltage drop in the cable and oversizing it to ensure that a proper motor terminal voltage is present.
Anyway ever heard of this term before?
Thanks in adavance
TULUM
Thanks in adavance
TULUM
