Has anyone ever designed a stud connection (aluminum base metal. Stainless Stud) with a "jam" nut applied against the same base metal as the stud - i.e. drill and tap, apply the stud (with locite), then add a jam nut and torque to the value for stainless? This a box with 4 studs, one per corner.
That arrangement is inserted into a support plate and a another nut is added and torqued again. ( I believe this would unload the first jam nut, ) I also believe the jam nut is detrimental and may lead to excessive bending. The assembly is loaded in three directions, high shock and vib.).
Not my design.....but I'm trying to correct it before a failure occurs.
Boozer
Boozer
