I live in a area where the wind comes from the North-West most of the year. In winter (when the air is denser) the wind velocities are very high. So with this in mind I was thinking of building a funnel (5m X 5m entrance reduced to a 0.5m dia cylinder. Inside the cylinder ther would be a one or multiple stage turbine (static vanes and power vanes). I would like your comments on this and some usefull equations. I used Area1 * Speed1 = Area2 * Speed2, this gives me incredibly high velocities for the ratio previously detailled (higher than the speed of sound). Q1. Is the air density reduced as you funnel it? What do you think the efficiency (in %) of a turbine can be?
