All,
I’m trying to calculate a rough furnace exit gas temperature (FEGT). Does the following calculation make sense?
FEGT = ((Total Boiler Heat Input - Furnace Heat Input) + (Boiler Air Flow * Specific Heat Capacity of Air * (Air Heater Outlet Temp - Air Heater Inlet Temp)))/(Boiler Exit Gas Flow * Flue Gas Heat Capacity)
Any input is appreciated. Thank you.
