ChopperChris
I have a motorcycle that I'm trying to put 6 LEDs on. The battery is a 9V wet cell and I'm trying to route the LEDs off the headlight circuit which uses a 10A fuse. I'm trying to use 20mA LEDs. Can anyone please tell me what I need to do to make this work? I was hoping to just route it off the positive end of the headlight bulb and connect the LEDs in series all the way to the negative end of the bulb. I figured there would be enough power to make both work. Thank you.
