Fuses for CCVT
cuky2000
2,133
We do have a design with fuses on the CVT box and fuses in series with the CVT one located in a common junction box.
I understand some utilities prefer eliminate any type of fuse on instrument transformer to minimize the possibility of down time.
Consulting usually comply with the NEC and like to protect a least with one set of fuses.
a) It is test link (dummy fuses) is a recommended solution instead fuses in series?
b) If fuses should be used, are the line fuses larger than the upstream fuses in the CVT?
Thanks in advance for your comments.
