alolesen
- Jul 21, 2005
- 88
Has anyone out there created a custom Hole Wizard database for G Series British Straight Pipe Thread holes? I have been trying to do this based on the ANSI Inch standard, but I am not having any luck. The format seems fairly straight forward, but I never seem to get the desired outcome. Either the hole or annotation dimensions are not correct or I seem to loose some parameter and end up with a 0 diameter hole.
I was able to create two custom databases for dowel pin holes, based on ANSI Inch plane holes, but the threaded hole format has me stumped.
