IVANKO
- Aug 6, 2013
- 3
I have to weld a small threaded nozzle (similar to a coupling) on the shell of my 500 [psi] vessel.
Only material I have available is G40.21 44W, hot rolled 2" bar. The small nozzle will be machined out of this bar.
COMPRESS returns - in its list of materials - only the G40.21 38W. Heat treatment is not an issue since the bar in hot rolled, but the real issue here is:
can I use the 44W in place of the listed 38W?
What do I have to do to be able to use the 44W in lieu of the 38W?
Thank you for your posts
