We are designing a wood building 80 x 100 16 ft side wall roof slope 3/12 thus peak height about 22 ft. We plan using 16 ft studs 2x8. At the gable end would you use laminated studs from foundation to roof? Or build the end to same height as the sidewall and then frame from there to the roof with regular studs and brace the "hinge" at the 16 ft mark to the roof structure in the attic. Many builders seem to be doing that
