Galley Standard Interface and Design Requirements 1
BandaGunda
Aerospace
Nov 12, 2019
5
Please - Could any one provide me with a sample *Galley Standard Interface/Design Requirements/structural interface document*. Any aircraft either Part 23 or Part 25. For academic use. Thanks.
BG...
Had to do some MIL galley design a few years ago... Galleys are NOT trivial systems, for various reasons.
Most of these documents relate to various aspects and inter-related elements... and contain numerous 'other references'...
xxxxxxxxxxxxx
SAE AIR1453 Disinfectant Cleaner for Aircraft Interior General Purpose Liquid
SAE AIR1826 Acoustical Considerations for Aircraft Environmental Control System Design
SAE AIR4766/2 Airborne Chemicals in Aircraft Cabins
SAE ARP85 Air Conditioning Systems for Subsonic Airplanes
SAE ARP583 Cabin Crew Stations
SAE ARP695 GALLEY SYSTEM DESIGN AND INSTALLATION CRITERIA
SAE ARP712 GALLEY LIGHTING
SAE ARP4712 Hand-Held Cabin Fire Extinguishers Transport Aircraft
SAE ARP5150 Safety Assessment of Transport Airplanes in Commercial Service
SAE ARP5770 Mechanical Control Design Guide
SAE ARP8058 Thermal Design and Performance of Airplane In-Flight Food Storage Carts
SAE AS1426 STANDARD GALLEY SYSTEM SPECIFICATION
SAE AS6271 Halocarbon Clean Agent Hand-Held Fire Extinguisher
SAE AS8036 Cargo Compartment Fire Detection Instruments
SAE AS8056 Minimum Design and Performance of Airplane Galley In-Flight Carts, Containers, and Associated Components
SAE AS8057 MINIMUM DESIGN AND PERFORMANCE OF AIRPLANE GALLEY INSERT EQUIPMENT, ELECTRICAL/PRESSURIZED
GAMA Publication No. 13: Acceptable Practices Document, Cabin Interior Monument Structural Substantiation Methods
FAA AC25.1455-1 Waste Water/Potable Water Drain System Certification Testing
MIL-HDBK-802 DESIGN OF ELECTRICAL EQUIPMENT WITH SMALL STRAY MAGNETIC FIELDS
MIL-STD-1472 HUMAN ENGINEERING
MIL-STD-1474 NOISE LIMITS
MIL-STD-1587 MATERIAL AND PROCESS REQUIREMENTS FOR AEROSPACE WEAPONS SYSTEMS
xxxxxxxxxxxx
Regards, Wil Taylor
o Trust - But Verify!
I'd add the FAR requirements …
general design and construction … 25.691-625
interiors … 25.785, 787, 789
loads 25.561 (and also typical abuse loads)
I wanted to suggest GAMA 13, but Wil beat me to it (as usual).
WKT; I am with you on all items you list, except the last one. A lot of things have to go wrong before the galley becomes, err, a projectile.
MIL-STD-1587? There are metallic materials recommendations and restrictions for MIL galleys due to fire, corrosion, EE EL shorts-grounding, plumbing,etc...
Gag me... that was a way-out-of-the-box project for my group.
Regards, Wil Taylor
Oh. I get it. You're not putting coffee cups and wet napkins in these particular "carts", are you?
Nudge-nudge wink-wink say no more...
If you have a friend at Boeing and can get the required permission, here are some other documents that might help. I cannot supply them as I do not work for Boeing and do not have their permission.
D6-36075 Galley Insert Design Requirements and Certification Methods
D6-55441 Galley/Interior Furnishing Structural Requirements
D6-55698 Design and Certification Requirements for Galleys, Closet, Stowages, Partitions and Crew Rests
SW... Coffee makers and ovens [conventional and microwave] are genuine hazards.
NOTE.
My company has extensive design references for galleys that I cannot mention... but most OEMs and large companies should have design guidance, documents/procedures, LL's, specs, etc in their library.
Regards, Wil Taylor
many thanks to WKT, rh, Spar & deb, for these useful information & discussions. cheers.
