Galvanic corrosion on Aluminium that is coated with Iridite NCP
Ale_Ian_8
Materials
Feb 1, 2021
1
Hi all,
Can you advise whether an Aluminium surface coated with Iridite NCP should be protected from Galvanic Corrosion?
The Galvanic Corrosion would be between the coated Aluminium and connectors made from Copper Beryllium, (Gold-Plated), Brass (Gold-Plated) and 400 Series Stainless Steel.
Thank you in advance,
Stay Safe,
Ale_Ian_8
