GALVANIZED STEEL GATE FOR AIRPORT PERIMETER FENCE 2
Erasa
44
Hi Engineers,
Can someone help me with standard reference for galvanized steel gate for airport perimeter fence?
Erasa
I assume you want a chain-link fence with barb wire on top???
Location????
Jim
swinging? on rollers? motorized? size? attack resistance? security? monitoring? gatehouse?... just some questions.
Thanks Jed... there are at least a couple of packrats around...
Jed...
Been there, done that. :) My electronic engineering library is around 12 GB. Unfortunately, it's only about half curated. I also have dozens of binders on various topics and a couple dozen bankers of personal project archives, the latter requiring a mini storage locker. I keep it all, of course, for when they open my wing at the Smithsonian. :)
Fred
--Winston S. Churchill
rookie... I have thousands of files, I can no longer locate.
Every time I open a cut sheet, I save it to my "Catalogue and Data Sheets" Folder. If I've opened it once, there's about a 90% chance I'll need it again. Same with technical references, which go ion a different folder, a lot of which I've found in Eng-Tips.
It helps that File Explorer has a relatively good search module. Last week one of my coworkers wanted a reference on lateral supports on auger cast piles. I went to my main dumping ground ("Misc"), searched under "auger" and found an FHWA reference called "Drilled Shafts: Construction Procedures and LRFD Design Methods." The search function not only looks under the titles, but goes into the text of the document.
Believe me, it's not foolproof (please no comment), but it's bailed me out many times.
