I moved into a house 3 years ago that had a new garage with a wood floor and basement underneath. The floor is painted 3/4" plywood on 2x12 joists 12" OC. The joist span is about 13 feet. The previous owner had built the garage and had placed diamond plate over the plywood in the areas where the car wheels run.
Over the last three years, water has run off the cars from melting snow, and even though I try to vacuum it all up, it has started to delaminate some of the plywood, it has gotten under the diamond plate which is rusting badly.
I am looking for something to overlay onto the garage floor that is durable, light and relatively inexpensive. In a perfect world, I would like to slope the floor to the doors to drain the water.
I've thought about light weight concrete or a thin coat epoxy. I can slope the concrete, but the weight may be too much. The epoxy is light, but being liquid, can't really be sloped. It also is hard and thin. While the floor has no noticable spring to it, I'm also afraid of it cracking and ruining the watertight seal.
Does anyone have any suggestions?
Ed
Ed
