Morph711
Petroleum
- Apr 21, 2021
- 12
Folks,
Am I correct in thinking that a significant drop in gas temperature upstream of a Compressor will result in gas being denser? Resulting in increased mass flowrate throughput. With the recycle flow around the Compressor being set in manual. The Compressor discharge tripped on high temperature because the re-cycle valve was not closed in fast enough.
