danschwind
- Sep 12, 2018
- 191
Hi everyone,
I’ve been comparing my compressors with the expected performance curves supplied by the OEM (I have multiple MW curves) and things are going well, where I often see a degradation on the compressor both on a polytropic head basis as well as on a polytropic efficiency, as expected for a compressor being subjected to a dirty gas that is operating for quite a few years.
For some compressors, I find that the current operating point is very close or even slightly above the theoretical curve supplied by the OEM, which I relate to a normal variance in the expected to real performance curve. I even expect that the theoretical curve to be a little bit conservative (less performance) than the real due to performance guarantees and whatnot.
However, for a particular set of compressors (the second stage of a 2-stage bundle machine), I’m finding values that are too good to be true. For other identical set, the values are within what I expect: some degradation compared to the theoretical curve. For the particular set, the current operational point seems to be so much greater than the theoretical curve that it seems I have a super-compressor in hand, where the current operating point in the performance curve is closer to the curve for a gas 5 kgmol/kg heavier than my current gas (!!!), even though the polytropic efficiency itself (which I calculate with the temperatures) is degraded. Note that the first stage of the same bundle has a behavior of a degraded compressor as I would expect.
I’ve asked for calibration of the suction flowmeter and the results were the same. Only thing pending related to measurements would be an orifice plate inspection to check any blockage, but it will take some time for this to happen (probably a few months).
I’ve been wondering if anyone has gone through the rabbit hole of evaluating their compressors and found results like this as well…was it due to bad field measurements or was the compressor really a super-performer?
I can post the overall data here if you guys really want to do some calculations but that is not really my point…just curious about others experience with this.
Best regards,
Daniel
Process Engineer
Rio de Janeiro - Brazil
Best regards,
Daniel
Process Engineer
