Gas Speed under Labyrinth seal.
204
How to determine the required gas speed under across labyrinth seal ?
Does it matter if the gas is hazardous or not ?
Leakage speed at the labby seals are dependent to temperature, delta pressure between fwd-aft side, RPM, gas density, viscosity, closure at the seal rotor-stator interface.
Didn't get the hazardous portion, "hazardous" is an adjective it's not a physical property.
